Ana içeriğe geç
Western Digital My Book Mini USB Port Replacement
Neye ihtiyacın var
  1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: adım 1, 3 resimden 1. Western Digital My Book Mini USB Port Replacement, Mini USB Port: adım 1, 3 resimden 2. Western Digital My Book Mini USB Port Replacement, Mini USB Port: adım 1, 3 resimden 3.
    • Start by turning the device port side up.
    • With the plastic opening tool, pry along the edges of the case.
    • When you hear the case snap-out of its fitted grooves, slowly slide the board assembly out of the case.
  2. Western Digital My Book Mini USB Port Replacement: adım 2, 1 resimden 1.
    • Gently pull the three pronged, clear plastic piece from the rubber holder.
  3. Western Digital My Book Mini USB Port Replacement: adım 3, 1 resimden 1.
    • Unscrew the two screws from the motherboard.
  4. Western Digital My Book Mini USB Port Replacement: adım 4, 1 resimden 1.
    • Remove all the rubber pieces from the four corners to unhinge the motherboard.
  5. Western Digital My Book Mini USB Port Replacement: adım 5, 1 resimden 1.
    • Remove the motherboard.
    • Set aside in a safe anti-static location.
  6. Western Digital My Book Mini USB Port Replacement: adım 6, 1 resimden 1.
    • Grab the mini USB port and align it with the appropriate metal docks on the motherboard.
  7. Western Digital My Book Mini USB Port Replacement: adım 7, 1 resimden 1.
    • Soldering irons can get HOT! Do not touch the iron tip, make sure it cools down for a good 30 minutes before touching the tip.
    • Start heating up the Soldering Iron, may take about 10–15 mins.
  8. Western Digital My Book Mini USB Port Replacement: adım 8, 1 resimden 1.
    • Solder together the four corners of the mini USB to the appropriate metal pieces on the motherboard.
    • Make sure the USB is firmly attached to the motherboard.
Sonuç
To reassemble your device, follow these instructions in reverse order from step 8.
8 farklı kişi bu kılavuzu tamamladı.
Gabriel Rael
333 İtibar
1 Kılavuz yazıldı
Ekip
Colorado Springs, Team 1-2, Mcmichael SU 2015 Colorado Springs, Team 1-2, Mcmichael SU 2015 üyesi
UCCS-MCMICHAEL-SU15S1G2
2 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 91
Her zaman: 16,024
