Ana içeriğe geç
Wexford CT-166TF Air Filter Casing Replacement
Neye ihtiyacın var
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: adım 1, 1 resimden 1.
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: adım 2, 3 resimden 1. Wexford CT-166TF Air Filter Casing Replacement: adım 2, 3 resimden 2. Wexford CT-166TF Air Filter Casing Replacement: adım 2, 3 resimden 3.
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: adım 3, 1 resimden 1.
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: adım 4, 2 resimden 1. Wexford CT-166TF Air Filter Casing Replacement: adım 4, 2 resimden 2.
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: adım 5, 2 resimden 1. Wexford CT-166TF Air Filter Casing Replacement: adım 5, 2 resimden 2.
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: adım 6, 1 resimden 1.
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: adım 7, 2 resimden 1. Wexford CT-166TF Air Filter Casing Replacement: adım 7, 2 resimden 2.
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: adım 8, 2 resimden 1. Wexford CT-166TF Air Filter Casing Replacement: adım 8, 2 resimden 2.
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: adım 9, 1 resimden 1.
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: adım 10, 2 resimden 1. Wexford CT-166TF Air Filter Casing Replacement: adım 10, 2 resimden 2.
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dannis Thompson
261 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017 üyesi
UWT-LINER-S17S3G4
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 614
