Ana içeriğe geç
Wexford CT-166TF Plastic Casing Replacement
Neye ihtiyacın var
  1. Wexford CT-166TF Plastic Casing  Replacement, Settings Knob: adım 1, 1 resimden 1.
    • Locate the knob at the top of the fan.
  2. Wexford CT-166TF Plastic Casing  Replacement: adım 2, 1 resimden 1.
    • Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
    • When reassembling, be sure to align the bottom of the new knob and the turning mechanism in the fan before pushing down.
  3. Wexford CT-166TF Plastic Casing  Replacement, Plastic Casing: adım 3, 1 resimden 1.
    • Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
  4. Wexford CT-166TF Plastic Casing  Replacement: adım 4, 2 resimden 1. Wexford CT-166TF Plastic Casing  Replacement: adım 4, 2 resimden 2.
    • Remove the four screws underneath the plastic covers.
  5. Wexford CT-166TF Plastic Casing  Replacement: adım 5, 2 resimden 1. Wexford CT-166TF Plastic Casing  Replacement: adım 5, 2 resimden 2.
    • Remove 5 smaller screws visible through small holes between the base and the casing.
  6. Wexford CT-166TF Plastic Casing  Replacement: adım 6, 2 resimden 1. Wexford CT-166TF Plastic Casing  Replacement: adım 6, 2 resimden 2.
    • Remove four screws on the back, two near the top and two near the bottom.
  7. Wexford CT-166TF Plastic Casing  Replacement: adım 7, 1 resimden 1.
    • Pull off the back casing.
  8. Wexford CT-166TF Plastic Casing  Replacement: adım 8, 2 resimden 1. Wexford CT-166TF Plastic Casing  Replacement: adım 8, 2 resimden 2.
    • Remove the 2 screws that attach the front part of the casing to the motor.
  9. Wexford CT-166TF Plastic Casing  Replacement: adım 9, 2 resimden 1. Wexford CT-166TF Plastic Casing  Replacement: adım 9, 2 resimden 2.
    • Remove the two middle screws attaching the black plastic cover to the front .
  10. Wexford CT-166TF Plastic Casing  Replacement: adım 10, 1 resimden 1.
    • Remove the two screws attached to the white bar near the red light on the top of the front casing.
  11. Wexford CT-166TF Plastic Casing  Replacement: adım 11, 1 resimden 1.
    • Remove the two screws keeping the button attached to the top of the casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cameron Mattson
101 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S3-G4, Liner Spring 2017 UW Tacoma, Team S3-G4, Liner Spring 2017 üyesi
UWT-LINER-S17S3G4
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 340
