Giriş
Wheels on roller luggage can wear down over time or even detach completely. When this happens, the best solution is a full wheel replacement.
This guide will demonstrate how to assess wheel damage and replace the wheels and axles of a Patagonia Black Hole® Wheeled Duffel.
Replacement parts are currently unavailable. To get your luggage fixed, take it in to a local Patagonia retail store for repair evaluation or send it in to Patagonia through their mail-in repair service.
Related Tutorials
Neye ihtiyacın var
Starting with an empty duffel, open the main zipper compartment.
Locate the zipper in the liner and open. This will expose the inside of the plastic wheel housing.
If the wheel and axle are missing, a nut and washer may be loose inside this liner compartment. Try to locate the washer and nut to reuse.
If the damaged wheel and axle are still attached, locate the axle nut inside the liner compartment and hold it in place with the adjustable wrench.
From the outside, turn the axle using the 4mm Allen wrench to free the wheel and axle from the plastic wheel housing. Save the washer and nut to reuse.
Test the other wheel for functionality and remove if it is broken.
Assess both wheels on the luggage:
Damaged Tread – If the wheel has a worn rubber tread or a flat spot (reference image #2), the wheel must be replaced, skip to Step 5.
Damaged Axle – If the original wheel is in working shape, but the axle is bent (reference image #3), continue to Step 4.
Missing Wheel – If both the wheel and axle are missing, skip to Step 5.
Responsibly discard any unusable pieces.
If the original wheel is in working shape, but the axle is bent, you can often free the wheel by cutting the axle off.
Using bolt cutters, cut the axle as close to wheel as possible.
If the cut axle remains stuck inside the wheel, elevate the wheel with a sturdy surface, and tap the cut end of the axle using a flat head screwdriver and a hammer until the axle is driven out.
There is often excess foam and lining fabric blocking access to the back of the plastic housing.
It is okay to cut away this excess using an X-Acto blade.
Place a new or salvaged wheel onto a new axle and insert the axle into the plastic wheel housing.
Inside the plastic wheel housing, place a washer and a nut onto the axle and finger-turn until attached.
Then use the adjustable wrench to keep the nut in-place and tighten the axle from the outside using the 4mm Allen wrench.
Check the function of the wheel by spinning the wheel or rolling the luggage on the floor.
Check the liner compartment to make sure no tools have been left behind.
Close the zipper to the liner compartment.
Bir başkası bu kılavuzu tamamladı.
