Giriş
Use this guide to replace the blower wheel on your Whirlpool dryer.
The blower wheel is a critical component that pulls the heated air through your dryer as it spins. It can be damaged by small pieces of laundry like socks or gloves that lodge in it and cause jams or breaks.
This guide will work for most Whirlpool dryers. This guide is written with a model WED87HED dryer. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Neye ihtiyacın var
Bu adımda kullanılan alet:FixMat$36.95
Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
Lift the control panel up and tilt it away from the chassis to remove it.
Use a small flat blade screwdriver or a spudger to unlatch both sides of the door switch connector.
Unplug the connector.
Remove the upper front panel sheet metal screws.
Tilt the machine backwards and prop it securely, or have a friend hold it.
Remove the sheet metal screws on the bottom edge of the panel.
Pull the bottom of the panel away from the chassis about two to three inches.
Lift the front panel off the small tabs on the chassis near the top of the panel and remove it.
Remove the green ground screw.
Remove the cord terminal block screws.
Remove the rear panel screws.
Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
Slide the panel off the vent pipe and remove it.
Make sure that the vent pipe is fitted into the collar on the panel.
Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
Position the panel so its screw holes match with the chassis.
Pull the lint filter up out of the lint filter slot to remove it.
Remove the mounting screws securing the lint filter housing.
Pull the filter housing outward from the chassis and down to remove it.
Lift the blower cover slightly and slide it to free the tabs which hold it in place.
Remove the blower cover.
Move to the rear of the machine to access the drive shaft.
Hold the drive shaft with an adjustable wrench on the hex portion of the drum drive pulley.
Use a socket wrench with an extension bar and no socket to fit into the square hole on the blower wheel.
Turn the wheel clockwise (to the right) to free it enough to remove it by hand.
Repair didn’t go as planned? Ask our Answers community for help.
