Ana içeriğe geç
Whirlpool Dryer Idler Arm Replacement
Neye ihtiyacın var
  1. Whirlpool Dryer Idler Arm Replacement, Safety Precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Idler Arm Replacement, Unfasten the top panel: adım 2, 3 resimden 1. Whirlpool Dryer Idler Arm Replacement, Unfasten the top panel: adım 2, 3 resimden 2. Whirlpool Dryer Idler Arm Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Idler Arm Replacement, Remove the top panel: adım 3, 2 resimden 1. Whirlpool Dryer Idler Arm Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Idler Arm Replacement: adım 4, 2 resimden 1. Whirlpool Dryer Idler Arm Replacement: adım 4, 2 resimden 2.
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Idler Arm Replacement, Unfasten the cover plate: adım 5, 1 resimden 1.
    • Remove the cover plate screw.
  6. Whirlpool Dryer Idler Arm Replacement, Remove the cover plate: adım 6, 3 resimden 1. Whirlpool Dryer Idler Arm Replacement, Remove the cover plate: adım 6, 3 resimden 2. Whirlpool Dryer Idler Arm Replacement, Remove the cover plate: adım 6, 3 resimden 3.
    • Remove the cover plate.
  7. Whirlpool Dryer Idler Arm Replacement, Disconnect the cord: adım 7, 1 resimden 1.
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  8. Whirlpool Dryer Idler Arm Replacement, Remove the cord: adım 8, 3 resimden 1. Whirlpool Dryer Idler Arm Replacement, Remove the cord: adım 8, 3 resimden 2. Whirlpool Dryer Idler Arm Replacement, Remove the cord: adım 8, 3 resimden 3.
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool Dryer Idler Arm Replacement, Unfasten the cord terminal block: adım 9, 1 resimden 1.
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  10. Whirlpool Dryer Idler Arm Replacement, Move the cord terminal block: adım 10, 3 resimden 1. Whirlpool Dryer Idler Arm Replacement, Move the cord terminal block: adım 10, 3 resimden 2. Whirlpool Dryer Idler Arm Replacement, Move the cord terminal block: adım 10, 3 resimden 3.
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool Dryer Idler Arm Replacement, Unfasten the rear panel: adım 11, 2 resimden 1. Whirlpool Dryer Idler Arm Replacement, Unfasten the rear panel: adım 11, 2 resimden 2.
    FixMat
    $36.95
    • Remove the rear panel screws.
  12. Whirlpool Dryer Idler Arm Replacement: adım 12, 2 resimden 1. Whirlpool Dryer Idler Arm Replacement: adım 12, 2 resimden 2.
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  13. Whirlpool Dryer Idler Arm Replacement, Remove the rear panel: adım 13, 3 resimden 1. Whirlpool Dryer Idler Arm Replacement, Remove the rear panel: adım 13, 3 resimden 2. Whirlpool Dryer Idler Arm Replacement, Remove the rear panel: adım 13, 3 resimden 3.
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool Dryer Idler Arm Replacement, Reassembly information: adım 14, 2 resimden 1. Whirlpool Dryer Idler Arm Replacement, Reassembly information: adım 14, 2 resimden 2.
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool Dryer Idler Arm Replacement, Unfasten the idler arm: adım 15, 2 resimden 1. Whirlpool Dryer Idler Arm Replacement, Unfasten the idler arm: adım 15, 2 resimden 2.
    • Remove the bolt securing the idler arm to the motor frame.
  16. Whirlpool Dryer Idler Arm Replacement, Remove the idler arm: adım 16, 3 resimden 1. Whirlpool Dryer Idler Arm Replacement, Remove the idler arm: adım 16, 3 resimden 2. Whirlpool Dryer Idler Arm Replacement, Remove the idler arm: adım 16, 3 resimden 3.
    • Move the idler arm toward the side of the dryer to unhook the idler arm tension spring from the arm.
    • Remove the idler arm.
    • During reassembly, be sure to reattach the spring before securing the arm.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
37.485 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 63
Her zaman: 730
