Ana içeriğe geç
Whirlpool Dryer Steam Nozzle Replacement
Neye ihtiyacın var
  1. Whirlpool Dryer Steam Nozzle Replacement, Safety Precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: adım 2, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: adım 2, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Steam Nozzle Replacement, Remove the top panel: adım 3, 2 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Steam Nozzle Replacement: adım 4, 2 resimden 1. Whirlpool Dryer Steam Nozzle Replacement: adım 4, 2 resimden 2.
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the cover plate: adım 5, 1 resimden 1.
    • Remove the cover plate screw.
  6. Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: adım 6, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: adım 6, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: adım 6, 3 resimden 3.
    • Remove the cover plate.
  7. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the cord: adım 7, 1 resimden 1.
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  8. Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: adım 8, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: adım 8, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: adım 8, 3 resimden 3.
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the cord terminal block: adım 9, 1 resimden 1.
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  10. Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: adım 10, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: adım 10, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: adım 10, 3 resimden 3.
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the rear panel: adım 11, 2 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the rear panel: adım 11, 2 resimden 2.
    FixMat
    $36.95
    • Remove the rear panel screws.
  12. Whirlpool Dryer Steam Nozzle Replacement: adım 12, 2 resimden 1. Whirlpool Dryer Steam Nozzle Replacement: adım 12, 2 resimden 2.
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  13. Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: adım 13, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: adım 13, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: adım 13, 3 resimden 3.
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool Dryer Steam Nozzle Replacement, Reassembly information: adım 14, 2 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Reassembly information: adım 14, 2 resimden 2.
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: adım 15, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: adım 15, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: adım 15, 3 resimden 3.
    • Push the retaining clip out with a small screwdriver or spudger.
    • Grab the retaining clip with your fingertips and remove it.
  16. Whirlpool Dryer Steam Nozzle Replacement: adım 16, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement: adım 16, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement: adım 16, 3 resimden 3.
    • Press the yellow sleeve toward the valve to release the water tube.
    • While holding the sleeve in place, pull the water tube out of the sleeve
  17. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the nozzle cover: adım 17, 1 resimden 1.
    • Remove the sheet metal screw securing the steam nozzle cover.
    • Be careful not to drop any tools as you work, or you may chip the drum's enamel coating
  18. Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: adım 18, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: adım 18, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: adım 18, 3 resimden 3.
    • Lift the lower edge of the cover and tilt it outward to clear the nozzle.
    • Slide the cover down to disengage the tab at the upper end of the cover.
    • Remove the cover.
  19. Whirlpool Dryer Steam Nozzle Replacement, Unfasten nozzle assembly: adım 19, 1 resimden 1.
    • Remove the nozzle assembly screw.
  20. Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: adım 20, 3 resimden 1. Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: adım 20, 3 resimden 2. Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: adım 20, 3 resimden 3.
    • Lift the nozzle assembly up to disengage the tab at the lower end.
    • Remove the nozzle assembly.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
37.485 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 33
Her zaman: 303
