Ana içeriğe geç
Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement
Neye ihtiyacın var
  1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement, Main Board: adım 1, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement, Main Board: adım 1, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement, Main Board: adım 1, 3 resimden 3.
    • Before attempting this repair, it is crucial to unplug your dryer to prevent electric shock.
    • Use a T5 Torx screwdriver to remove two 6.3 mm screws. from the top back of the dryer.
  2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 2, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 2, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 2, 3 resimden 3.
    • Slide the top of the dryer off to access the internal components.
    • Use a T5 Torx screwdriver to remove two 6.3mm screws.
    • The circuit board is mounted on a metal rack..
  3. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 3, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 3, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 3, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the 6.3 mm screws on both ends of the metal shelve.
    • Slide the metal shelve out to access the main board.
  4. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 4, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 4, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 4, 3 resimden 3.
    • Remove all the circuit wires from the circuit board. Grab the circled wire to remove.
    • Remove the other wires.
    • Work at an angle with the metal mount still inside the dryer.
  5. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 5, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 5, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 5, 3 resimden 3.
    • Keep removing the wires until every wire is disconnected from the old circuit.
  6. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 6, 1 resimden 1.
    • Once you've disconnected the wires, the wires should look like this in the image.
  7. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 7, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 7, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 7, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the 6.3mm screw.
    • Use your hand to grab the old circuit and move it from the left to the right to get the circuit removed.
    • There should not be anything on the board.
  8. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 8, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 8, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 8, 3 resimden 3.
    • Use the new circuit to put in the board. Ensure the two white hooks are connected to the metal base.
    • Use the T5 Torx screwdriver to screw the 6.3mm screw to the new circuit attached to the metal board.
    • The new circuit shouold be tight to the metal
  9. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 9, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 9, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 9, 3 resimden 3.
    • Attach the orange and red wires into the circuit.
    • Do to the same for the other wires
  10. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 10, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 10, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 10, 3 resimden 3.
    • Insert the red and white wires into the circuit.
  11. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 11, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 11, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 11, 3 resimden 3.
    • Refer to the image for where to insert the wires.
  12. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 12, 2 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 12, 2 resimden 2.
    • Attach the white wire to the circuit.
  13. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 13, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 13, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 13, 3 resimden 3.
    • Use the T5 Torx screwdriver to screw the 6.3mm screw at both sides of the metal board.
  14. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 14, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 14, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 14, 3 resimden 3.
    • Reattach the top board
    • Use a T5 Torx screwdriver to screw the left 6.3mm screw into the top of the board
  15. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 15, 3 resimden 1. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 15, 3 resimden 2. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 15, 3 resimden 3.
    • Use a T5 Torx screwdriver to screw the 6.3mm screw on the right.
  16. Whirlpool Duet Dryer WED9200SQ1 Main Board Replacement: adım 16, 1 resimden 1.
    • Once you are done screwing the back, the dyer should be ready to use.
Sonuç
Cesar Vazquez
253 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 102
