Ana içeriğe geç
Whirlpool Refrigerator Auger Motor Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Auger Motor Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: adım 2, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: adım 2, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement, Open the doors: adım 2, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  3. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: adım 3, 2 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker tray: adım 3, 2 resimden 2.
    • Pull the icemaker tray completely out of its slot in the chassis.
  4. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker assembly: adım 4, 2 resimden 2.
    • Remove the screw(s) securing the icemaker assembly.
    • The second photo shows the potential screw locations in a removed icemaker assembly.
  5. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker assembly: adım 5, 3 resimden 3.
    • Pull the icemaker assembly off its slot in the chassis.
    • Let the assembly hang to access its connectors.
  6. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker assembly: adım 6, 3 resimden 3.
    • Disconnect any connectors attached to the icemaker assembly.
  7. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker assembly: adım 7, 1 resimden 1.
    • Remove the icemaker assembly.
  8. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the icemaker auger assembly: adım 8, 1 resimden 1.
    • Remove the screw(s) securing the icemaker auger assembly.
  9. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement, Reposition the icemaker auger assembly: adım 9, 3 resimden 3.
    • Pull the icemaker auger assembly off of its slot in the chassis.
  10. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the icemaker auger assembly: adım 10, 3 resimden 3.
    • Disconnect any connectors attached to the icemaker auger assembly.
  11. Whirlpool Refrigerator Auger Motor Replacement, Remove the icemaker auger assembly: adım 11, 1 resimden 1.
    • Remove the icemaker auger assembly.
  12. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: adım 12, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: adım 12, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement, Remove the auger fin: adım 12, 3 resimden 3.
    • Twist the auger fin clockwise until it separates from the assembly.
    • Remove the auger fin.
  13. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the grounding wire: adım 13, 1 resimden 1.
    • Remove the screw(s) securing the grounding wire.
  14. Whirlpool Refrigerator Auger Motor Replacement, Unfasten the auger motor: adım 14, 1 resimden 1.
    • Remove the screw(s) securing the auger motor.
  15. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: adım 15, 2 resimden 1. Whirlpool Refrigerator Auger Motor Replacement, Disconnect the auger motor: adım 15, 2 resimden 2.
    • Use needle nose pliers, or your hands, to disconnect the grounding wire from the auger motor.
  16. Whirlpool Refrigerator Auger Motor Replacement: adım 16, 3 resimden 1. Whirlpool Refrigerator Auger Motor Replacement: adım 16, 3 resimden 2. Whirlpool Refrigerator Auger Motor Replacement: adım 16, 3 resimden 3.
    • Disconnect the connectors attached to the auger motor.
  17. Whirlpool Refrigerator Auger Motor Replacement, Only the auger motor remains: adım 17, 1 resimden 1.
    • You're now left with the auger motor.
  18. Whirlpool Refrigerator Auger Motor Replacement, Meter the auger motor: adım 18, 1 resimden 1.
    • If you own a multimeter, you can test your auger motor's resistance.
    • A range between 5-50 Ω is acceptable.
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 İtibar
89 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
45 Üyeler
707 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 57
Her zaman: 1,552
