Ana içeriğe geç
Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Safety precautions: adım 1, 1 resimden 1.
    • Before you begin your repair, perform the following:
    • Turn off your main water supply
    • Unplug your device
  2. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Unfasten the dispenser panels: adım 2, 2 resimden 1. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Unfasten the dispenser panels: adım 2, 2 resimden 2.
    • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
    • Remove the screw(s) securing the two dispenser panels.
  3. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the dispenser panels: adım 3, 3 resimden 1. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the dispenser panels: adım 3, 3 resimden 2. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the dispenser panels: adım 3, 3 resimden 3.
    • Pull the dispenser panels straight down to separate them from the chassis.
    • Remove the dispenser panels.
  4. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Unfasten the control board: adım 4, 1 resimden 1.
    • Remove the screw(s) securing the control board.
  5. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement: adım 5, 3 resimden 1. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement: adım 5, 3 resimden 2. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement: adım 5, 3 resimden 3.
    • Tilt the bottom of the control board away from the chassis to release its clips.
    • Pull straight down to separate the control board enough to access its connectors.
  6. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Disconnect the control board: adım 6, 3 resimden 1. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Disconnect the control board: adım 6, 3 resimden 2. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Disconnect the control board: adım 6, 3 resimden 3.
    • Disconnect the connectors attached to the control board.
  7. Whirlpool Refrigerator Stainless Steel - WRS588FIHZ Control Board Replacement, Remove the control board: adım 7, 1 resimden 1.
    • Remove the control board.
Sonuç
Matt Zieminski
45.297 İtibar
13 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.829 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 222
