Ana içeriğe geç
Whirlpool Refrigerator Water Filter Replacement
Neye ihtiyacın var
  1. Whirlpool Refrigerator Water Filter Replacement, Open the doors: adım 1, 3 resimden 1. Whirlpool Refrigerator Water Filter Replacement, Open the doors: adım 1, 3 resimden 2. Whirlpool Refrigerator Water Filter Replacement, Open the doors: adım 1, 3 resimden 3.
    • Depending on your repair, open one or both doors.
  2. Whirlpool Refrigerator Water Filter Replacement, Water Filter: adım 2, 3 resimden 1. Whirlpool Refrigerator Water Filter Replacement, Water Filter: adım 2, 3 resimden 2. Whirlpool Refrigerator Water Filter Replacement, Water Filter: adım 2, 3 resimden 3.
    • Pull the water filter door in the base grill open.
  3. Whirlpool Refrigerator Water Filter Replacement: adım 3, 3 resimden 1. Whirlpool Refrigerator Water Filter Replacement: adım 3, 3 resimden 2. Whirlpool Refrigerator Water Filter Replacement: adım 3, 3 resimden 3.
    • As the door opens, the filter gets ejected out.
    • When the filter is fully ejected, pull the filter out.
    • A towel is suggested as water might spill while pulling the old filter out.
  4. Whirlpool Refrigerator Water Filter Replacement: adım 4, 2 resimden 1. Whirlpool Refrigerator Water Filter Replacement: adım 4, 2 resimden 2.
    • Get the new filter out of its packaging.
    • Remove the covers from the filter inlets. Make sure the O-rings stay on the filter.
  5. Whirlpool Refrigerator Water Filter Replacement: adım 5, 2 resimden 1. Whirlpool Refrigerator Water Filter Replacement: adım 5, 2 resimden 2.
    • Align the new filter with the filter housing and insert filter into place.
    • The arrows should be facing the same way.
  6. Whirlpool Refrigerator Water Filter Replacement: adım 6, 3 resimden 1. Whirlpool Refrigerator Water Filter Replacement: adım 6, 3 resimden 2. Whirlpool Refrigerator Water Filter Replacement: adım 6, 3 resimden 3.
    • Close the filter cover door completely to snap the filter into to place correctly. You will hear a snap!
  7. Whirlpool Refrigerator Water Filter Replacement, Flush the water system: adım 7, 2 resimden 1. Whirlpool Refrigerator Water Filter Replacement, Flush the water system: adım 7, 2 resimden 2.
    • Flush the water system by holding the water dispenser for 5 seconds and releasing for 5 seconds repeating this step until water begins to flow.
    • After water flowing, get at least a total of 3 gallons dispensed in order to see full flushed water results.
  8. Whirlpool Refrigerator Water Filter Replacement: adım 8, 3 resimden 1. Whirlpool Refrigerator Water Filter Replacement: adım 8, 3 resimden 2. Whirlpool Refrigerator Water Filter Replacement: adım 8, 3 resimden 3.
    • You may need to reset the filter indicator by pushing the switch 5 times in a row.
    • When the filter indicator is reset, the light should change from red to green.
Sonuç
After flushing the water system completely, get ready to have some refreshing water with a cup of ice freshly made with the new installed water filter.
Bir başkası bu kılavuzu tamamladı.
brenda lopez
366 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 11-30, Grodsky Fall 2021 CSU Los Angeles, Team 11-30, Grodsky Fall 2021 üyesi
CSULA-GRODSKY-F21S11G30
1 Üye
3 adet Kılavuz yazıldı
8Kılavuz Yorumları
Changed filter but now water is not coming out of the dispenser. Installed filter correctly per pictures. What could be the problem?
SewFrau58 - Yanıt
You will have air in the system after changing the filter. Make sure you did turn the water on. Run the water dispenser until water pushes the air out. Run the water until it clears.
Fredric - Yanıt
Opened the filter door but the filter did not eject. Any troubleshooting advice on how to remove the filter?
Ariana Vega - Yanıt
You'll want to rotate the filter counterclockwise until it pops out.
nicO -
Filter door will not open all the way.
cjw - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 113
Son 30 gün: 454
Her zaman: 18,230
