Ana içeriğe geç
Whirlpool WGD4800XQ Thermal Fuse Replacement
Neye ihtiyacın var
  1. Whirlpool WGD4800XQ Thermal Fuse Replacement, Thermal Fuse: adım 1, 1 resimden 1.
    • Unplug the dryer from the power outlet.
  2. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 2, 2 resimden 1. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 2, 2 resimden 2.
    • Unscrew the backplate by rotating each screw counterclockwise with a ratchet and 8mm socket.
    • The screws are located around the edges of the backplate.
    • The backplate is a heavy object. Hold the backplate while removing the screws or get assistance. Dropping the backplate can cause injury or break the gas pipe.
  3. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 3, 1 resimden 1.
    • Lift the backplate off of the dryer.
  4. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 4, 1 resimden 1.
    • Pull out the blue terminal cables on the thermal fuse with a needle nose plier.
    • Keep track of what terminal fuse goes on top and bottom.
  5. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 5, 1 resimden 1.
    • Remove the screw from the thermal fuse with the ratchet and 8mm socket.
  6. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 6, 1 resimden 1.
    • Place the new thermal fuse and secure the screw with the ratchet and 8 mm socket.
  7. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 7, 1 resimden 1.
    • Insert the blue terminal cables to the thermal fuse with a needle nose plier.
  8. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 8, 2 resimden 1. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 8, 2 resimden 2.
    • Put the back plate on the dryer.
    • If possible, have someone hold it up to align all the holes on the backplate and dryer while you use the ratchet and 8 mm socket to replace the screws.
  9. Whirlpool WGD4800XQ Thermal Fuse Replacement: adım 9, 1 resimden 1.
    • Connect the dryer to the power outlet.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 70
Her zaman: 1,687
