Ana içeriğe geç
Whirlpool Washing Machine Lid Lock Assembly Replacement
Video Kılavuzu
Bu kılavuz bir YouTube videosundan alınmıştır.
Neye ihtiyacın var
      • Unplug the washing machine from the wall and close both water supply valves.
      • Slide the washer forward so you can reach the back panel comfortably.
      FixBot'a Sor
      Yorum Ekle
      • Remove the two quarter-inch screws at the back corners that secure the top panel.
      • Remove the quarter-inch screw in the small wire-harness cover and lift the cover off.
      FixBot'a Sor
      Yorum Ekle
      • Remove the five screws holding the rear console cover and pull the metal cover away.
      FixBot'a Sor
      Yorum Ekle
      • Push the basket rearward, reach under the lid, and press the two hidden spring clips to pop the console loose, or slide a flexible plastic card into the gap from the front to release them.
      • Avoid metal tools because they scratch the plastic trim badly.
      • Swing the console up, press the tab on its single wire connector, and unplug it from the control board.
      FixBot'a Sor
      Yorum Ekle
      • Unplug the lid-lock harness and any other wiring leading into the top panel.
      • Pull the small pressure hose straight off its port on the control board.
      • Remove the green ground strap held by a quarter-inch screw if it blocks the panel.
      FixBot'a Sor
      Yorum Ekle
      • Raise the rear edge of the lid and top assembly high, push it forward to free the rear clips, then move to the front and lift upward while pulling back to release the front tabs.
      • Pivot the entire top toward the rear wall and rest its edges in the two metal fingers on the chassis so it cannot fall.
      FixBot'a Sor
      Yorum Ekle
      • Slip a fingernail or thin plastic tool under the bezel tabs on the lid surface and gently pry it free from the lock body.
      • The bezel is thin and cracks easily, so work slowly and do not twist hard.
      FixBot'a Sor
      Yorum Ekle
      • Push the lock assembly to the left, lift it slightly, then slide it right and out of the lid opening.
      FixBot'a Sor
      Yorum Ekle
      • Use a flat-blade screwdriver to pry the two metal retainers open and pull the harness trunk out of them.
      • Press the tab on the small plastic retainer and release the harness from the top side of the lid.
      FixBot'a Sor
      Yorum Ekle
      • Thread the replacement harness through the lid hole and seat it into the two metal clips.
      • Snap the plastic retainer back into the lid to secure the harness slack.
      FixBot'a Sor
      Yorum Ekle
      • Insert the top of the lock body into the left side of the opening, press it flush against the lid, and slide it firmly to the right until the side tab clicks.
      FixBot'a Sor
      Yorum Ekle
      • Align the bezel over the lock and press until all four tabs click flat against the lid surface.
      • If the bezel will not seat, the lock is not fully latched into its housing.
      FixBot'a Sor
      Yorum Ekle
      • Guide the top back onto the chassis, rock it forward, down, and back until the front and rear clips snap flush.
      • Lift the rear edge again slightly if needed to be sure every latch is locked tight.
      FixBot'a Sor
      Yorum Ekle
      • Reinstall the green ground strap with its screw and plug every harness back into the control board.
      • Set the console on its hinges and push until the spring clips click into the lid housing.
      FixBot'a Sor
      Yorum Ekle
      • Install the metal console back cover with its five screws.
      • Replace the wire-harness cover screw, then reinstall the two quarter-inch top screws removed earlier.
      FixBot'a Sor
      Yorum Ekle
      • Open the water supply valves and plug the washer back into the outlet.
      FixBot'a Sor
      Yorum Ekle
      • Verify all lights are off, then press the same three keys in order three times within eight seconds (1-2-3, 1-2-3, 1-2-3) to enter diagnostics.
      • Wait for the indicator lamps to flash, press the second key (Rinse) once, then press Start to launch the automatic test cycle for calibration.
      • Allow about five minutes for the test to complete and confirm proper lock operation.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
7.128 İtibar
224 adet Kılavuz yazıldı
1Rehber Yorum
What do u do wen the 123 123 123 method dose not work... ??
JORDAN M M PELLETIER - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 40
Son 30 gün: 138
Her zaman: 750
