Giriş
Third Guide in this series covering various aspects of this device. This one on M.2 SSD replacement.
Neye ihtiyacın var
Remove the two screws holding the battery in place.
Slip your finger into the finger hole provided at the top of the battery.
...and lift to remove it
Remove the five Phillips screws securing the bottom to the case.
Slide the cover up slightly to release the clips holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
Slide the bottom cover to remove it.
Remove the Phillips screw securing the M.2 SSD drive in place. The end of the drive will pop up by a small amount.
Slide the drive out from the connector in a straight line. If you feel resistance, try raising it slightly.
To reassemble your device, follow the instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
