Ana içeriğe geç
Why Face ID Not Working After Repair
Videoya Genel Bakış
  1. Why Face ID Not Working After Repair, Face ID System: adım 1, 2 resimden 1. Why Face ID Not Working After Repair, Face ID System: adım 1, 2 resimden 2.
    • There are 8 components packed into the front of the phone. Infrared Camera; Flood Illuminator; Proximity Sensor; Ambient Light Sensor; Speaker; Microphone; Front Camera; Dot Projector;
    • The infrared camera, the dot projector and the front camera are located on the back glass assembly.
    • The flood illuminator, the proximity sensor, the ambient light sensor, the speaker and the microphone are located on the display assembly.
    • Please be careful when disassembling or repairing the phone. Damage of any component will cause Face ID failure.
    • Please be noted that there is a slot on the display assembly. When assembling the phone, the fold of the speaker flex cable should be placed correspondingly in the slot to prevent the cable from getting broken. Which will also result in the failure of Face ID.
  2. Why Face ID Not Working After Repair, Disassemble The Flood Illuminator Module: adım 2, 1 resimden 1.
    • We can see that there are many holes on the flood illuminator that are arranged in a matrix of 11×11.
    • The chip is connected to the circuit board with the help of gold wires.
    • Once water damaged, these holes can be blocked. And you will be faced up with Face ID failure.
  3. Why Face ID Not Working After Repair, Chips On The Flood Illuminator Module: adım 3, 1 resimden 1.
    • Chip 1 is an unencrypted chip.
    • Chip 2 is the flood illuminator. Chip 3 and Chip 4 are proximity sensors that are responsible for receiving and transmitting respectively.
    • Independent of each other, the three chips are indispensable.
  4. Why Face ID Not Working After Repair, Disassemble The Dot Projector: adım 4, 1 resimden 1.
    • The outer layer of the dot projector is sealed with resin and protected by metal welding techniques.
    • Pay attention to these welding points. They can easily fall off once the phone is dropped. And once off, they cannot be restored.
    • Once the dot projector has been detached, we can see a crystal that looks just like a diamond lens.
    • The infrared light is emitted from here. Then reflected by the crystal. Its projection range is determined by the lens afterwards.
  5. Why Face ID Not Working After Repair, Internal Structure Of The Dot Projector: adım 5, 2 resimden 1. Why Face ID Not Working After Repair, Internal Structure Of The Dot Projector: adım 5, 2 resimden 2.
    • The chip on the left is used to store data, whereas the chip on the right side acts just like a projector. We can see that there are thousands of dots arranged here. The infrared light is emitted from here.
    • Since necessary power supply is needed for chip on the right side to work normally, once water damaged, circuits here are most likely to get short. Which can also result in Face ID not working.
    • And please be noted that the chip is exposed without black adhesive seal. So it can be easily damaged once water-damaged or dropped. What’s more, it also can not be restored once damaged.
  6. Why Face ID Not Working After Repair, The Crystal Part Of The Dot Projector: adım 6, 1 resimden 1.
    • We can see that there is a concave lens and a convex lens on the crystal. And the two are made of glass. Once dropped, Face ID can also be affected.
  7. Why Face ID Not Working After Repair, Face ID Fault-finding: adım 7, 1 resimden 1.
    • Judging by what we have learned during the disassembling, main circuits of the Face ID are exposed. Once water damaged or exposed to a relatively humid environment, there might be electricity leakage or short-circuit problem that can result in Face ID failure.
    • What’s more, most of the Face ID parts are made of glass. Once dropped, Face ID is most likely to be unavailable.
    • In summary, Face ID can be easily damaged and hard to be restored. Therefore, please be very careful in daily use. Make sure the phone is protected from water-damage or heavy falling. Repair technicians must exercise caution when repairing the logic board or replacing the display assembly.
Bitiş Çizgisi
36 farklı kişi bu kılavuzu tamamladı.
Phryne
20.329 İtibar
18 adet Kılavuz yazıldı
13 Yorum
Brilliant! keep up with your good work.
HAKU_LYU - Yanıt
Thanks for your support!
Phryne -
I send my iPhone for repair bcos not able to activate but instead my Face ID has problems now
Vian - Yanıt
Face ID relevant flex cables might have been ripped-off or relevant components were knocked-off during phone disassembly.
Phryne -
Best information I found on web about Face ID Failure. Keep up the great work.
Pranav Hargotra - Yanıt
I live in the US. Anyone here can fix FaceID on my iPhone 11?
Jared Guthrie - Yanıt
all of the above works for me, but there is no face id, what could be the problem?
Владислав Черных - Yanıt
Any procedure for my iPhone 11 Pro Max Face ID to be fix
Fest - Yanıt
Are there ways to determine if Face ID works or not? Right now every time I go to the settings to set up face ID it keeps showing turn the phone lower or higher but it doesn’t get to scan my face.
mohsin92 - Yanıt
Will my face id work if I changed the whole module including the camera and Is it okay to buy a copy module by verifying it. Does copy face id module have same quality of camera as of original.
dikshant Lamsal - Yanıt
So if my Face ID was disabled after some light exposure to water, will it re enable once the phone is left in some rice and the water drains out?
Mujtaba Khan - Yanıt
Does a phone with face ID failure work normal or does it affect anything else on the phone? Someone is selling me a phone but it face ID doesnt work, should i buy it ?
AXA Contracting - Yanıt
My Iphone X doesn't start (Still in the apple turning Up and off constantly). I tried with the software Itune and others, but it gives error 4013 aborting the restoration process. I saw in two videos on Youtube that it could be caused for fail in FACE ID card. But I know also that if you I replaced this card it could gimme one error for program in it. I would like to know your comment about all it.
Jean Carlos Alvarez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 102
Son 7 gün: 539
Son 30 gün: 2,444
Her zaman: 176,803
