Giriş
This guide will demonstrate how to remove and replace the feet on the Wii Balance Board.
Neye ihtiyacın var
Flip device upside-down so the plastic white board is facing the ground.
Locate the four feet in the corners of the Balance Board.
Unscrew the three 12.7 mm Phillips screws from each foot cover.
Remove the gray plastic ring from the actual foot by lifting it up.
Repeat steps two and three on the remaining four feet.
how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
2 Yorum
I am in need of a foot cover. Where can I find one??
This manual did not help
