Ana içeriğe geç
Wii Balance Board Front Cover Replacement
Neye ihtiyacın var
  1. Wii Balance Board Front Cover Replacement, Unscrewing the Foot Cover: adım 1, 1 resimden 1.
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Front Cover Replacement, Removing the Foot Cover: adım 2, 1 resimden 1.
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Front Cover Replacement, Removing the Foot: adım 3, 1 resimden 1.
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Front Cover Replacement, Removing the Additional Feet: adım 4, 1 resimden 1.
    • Repeat steps two and three on the remaining four feet.
  5. Wii Balance Board Front Cover Replacement, Unscrewing the Back Cover: adım 5, 1 resimden 1.
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Front Cover Replacement, Removing the Back Cover: adım 6, 1 resimden 1.
    • Lift off the gray back cover.
  7. Wii Balance Board Front Cover Replacement, Battery Compartment: adım 7, 2 resimden 1. Wii Balance Board Front Cover Replacement, Battery Compartment: adım 7, 2 resimden 2.
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Front Cover Replacement, Removing the Battery Case: adım 8, 1 resimden 1.
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
  9. Wii Balance Board Front Cover Replacement, Unscrewing the Frame: adım 9, 1 resimden 1.
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Front Cover Replacement, Removing the Frame: adım 10, 1 resimden 1.
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cory Olson
915 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-8, Forte Fall 2014 Cal Poly, Team 13-8, Forte Fall 2014 üyesi
CPSU-FORTE-F14S13G8
5 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 35
Her zaman: 1,724
