Ana içeriğe geç
Wii U GamePad LCD Display Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
Videoya Genel Bakış
  1. Wii U GamePad LCD Display Replacement, Battery: adım 1, 1 resimden 1.
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad LCD Display Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery plate.
  3. Wii U GamePad LCD Display Replacement: adım 3, 3 resimden 1. Wii U GamePad LCD Display Replacement: adım 3, 3 resimden 2. Wii U GamePad LCD Display Replacement: adım 3, 3 resimden 3.
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad LCD Display Replacement, Outer Case: adım 4, 3 resimden 1. Wii U GamePad LCD Display Replacement, Outer Case: adım 4, 3 resimden 2. Wii U GamePad LCD Display Replacement, Outer Case: adım 4, 3 resimden 3.
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad LCD Display Replacement: adım 5, 1 resimden 1.
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
  6. Wii U GamePad LCD Display Replacement, Speakers: adım 6, 2 resimden 1. Wii U GamePad LCD Display Replacement, Speakers: adım 6, 2 resimden 2.
    • With your fingers, unplug the left speaker cable from the motherboard.
  7. Wii U GamePad LCD Display Replacement: adım 7, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  8. Wii U GamePad LCD Display Replacement, Wi-Fi Board: adım 8, 3 resimden 1. Wii U GamePad LCD Display Replacement, Wi-Fi Board: adım 8, 3 resimden 2. Wii U GamePad LCD Display Replacement, Wi-Fi Board: adım 8, 3 resimden 3.
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  9. Wii U GamePad LCD Display Replacement: adım 9, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 9, 2 resimden 2.
    • With your fingers, lift and remove Wi-Fi board.
    • Remove the board carefully as there are still two wires attached.
  10. Wii U GamePad LCD Display Replacement: adım 10, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 10, 2 resimden 2.
    • Disconnect the black and white wires off of the back of the Wi-Fi module.
  11. Wii U GamePad LCD Display Replacement: adım 11, 1 resimden 1.
    • Lift and remove the Wi-Fi module.
  12. Wii U GamePad LCD Display Replacement, Motherboard: adım 12, 1 resimden 1.
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad LCD Display Replacement: adım 13, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 13, 2 resimden 2.
    • Remove the blue connector using tweezers.
  14. Wii U GamePad LCD Display Replacement: adım 14, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 14, 2 resimden 2.
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon.
    • Be careful, the small clasp breaks easily.
  15. Wii U GamePad LCD Display Replacement: adım 15, 1 resimden 1.
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad LCD Display Replacement: adım 16, 3 resimden 1. Wii U GamePad LCD Display Replacement: adım 16, 3 resimden 2. Wii U GamePad LCD Display Replacement: adım 16, 3 resimden 3.
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad LCD Display Replacement: adım 17, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 17, 2 resimden 2.
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad LCD Display Replacement: adım 18, 3 resimden 1. Wii U GamePad LCD Display Replacement: adım 18, 3 resimden 2. Wii U GamePad LCD Display Replacement: adım 18, 3 resimden 3.
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
  19. Wii U GamePad LCD Display Replacement, LCD Display: adım 19, 2 resimden 1. Wii U GamePad LCD Display Replacement, LCD Display: adım 19, 2 resimden 2.
    • Remove the four 5.1mm screws using Phillips size #0 screwdriver.
    • Pull the white and black cables away from the display case.
  20. Wii U GamePad LCD Display Replacement: adım 20, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 20, 2 resimden 2.
    • Lift and remove the grey display case with your fingers.
  21. Wii U GamePad LCD Display Replacement: adım 21, 2 resimden 1. Wii U GamePad LCD Display Replacement: adım 21, 2 resimden 2.
    • Gently with your fingers, press on the front of the display and it will lift up.
    • Remove the display with your fingers.
Sonuç
86 farklı kişi bu kılavuzu tamamladı.
Valentina Cerruty
3.500 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G6
4 Üyeler
40 adet Kılavuz yazıldı
20Kılavuz Yorumları
was really perfect to repair my device. Thank you very much for this help
Bernd Dietrich - Yanıt
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Stacey Hoggard - Yanıt
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Terry Moenkhaus -
Very happy with your manual! I've fixed it.
Paulus 68 - Yanıt
Mine did not come with the touch screen either.
Edwin Kahn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 176
Son 30 gün: 1,076
Her zaman: 108,706
