Ana içeriğe geç
Wii U GamePad Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Wii U GamePad Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery plate.
  3. Wii U GamePad Motherboard Replacement: adım 3, 3 resimden 1. Wii U GamePad Motherboard Replacement: adım 3, 3 resimden 2. Wii U GamePad Motherboard Replacement: adım 3, 3 resimden 3.
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Motherboard Replacement, Outer Case: adım 4, 3 resimden 1. Wii U GamePad Motherboard Replacement, Outer Case: adım 4, 3 resimden 2. Wii U GamePad Motherboard Replacement, Outer Case: adım 4, 3 resimden 3.
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Motherboard Replacement: adım 5, 1 resimden 1.
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
    • Do not pull on the wires as shown in this picture, they will likely break off. Pull directly on the plug (NOT the receptacle)
  6. Wii U GamePad Motherboard Replacement, Wi-Fi Board: adım 6, 3 resimden 1. Wii U GamePad Motherboard Replacement, Wi-Fi Board: adım 6, 3 resimden 2. Wii U GamePad Motherboard Replacement, Wi-Fi Board: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
    • Remove the white flex cable with the tweezers.
  7. Wii U GamePad Motherboard Replacement: adım 7, 2 resimden 1. Wii U GamePad Motherboard Replacement: adım 7, 2 resimden 2.
    • With your fingers, lift and remove Wi-Fi board.
    • Remove the board carefully as there are still two wires attached.
  8. Wii U GamePad Motherboard Replacement: adım 8, 2 resimden 1. Wii U GamePad Motherboard Replacement: adım 8, 2 resimden 2.
    • Disconnect the black and white wires off of the back of the Wi-Fi module.
  9. Wii U GamePad Motherboard Replacement: adım 9, 1 resimden 1.
    • Lift and remove the Wi-Fi module.
  10. Wii U GamePad Motherboard Replacement, Speakers: adım 10, 2 resimden 1. Wii U GamePad Motherboard Replacement, Speakers: adım 10, 2 resimden 2.
    • With your fingers, unplug the left speaker cable from the motherboard.
  11. Wii U GamePad Motherboard Replacement: adım 11, 2 resimden 1. Wii U GamePad Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the right speaker cable that's connected to the motherboard with the tweezers.
  12. Wii U GamePad Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Disconnect the analog connector with tweezers.
  13. Wii U GamePad Motherboard Replacement: adım 13, 2 resimden 1. Wii U GamePad Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the blue connector using tweezers.
  14. Wii U GamePad Motherboard Replacement: adım 14, 2 resimden 1. Wii U GamePad Motherboard Replacement: adım 14, 2 resimden 2.
    • Carefully lift the black clasp. It is prone to breaking if only lifted from one point. Remove the brown ribbon by using the tweezers.
    • Unclasp and release the small digitizer ribbon cable to the left of the brown ribbon.
    • Be careful, the small clasp breaks easily.
  15. Wii U GamePad Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove the small orange ribbon with the tweezers.
  16. Wii U GamePad Motherboard Replacement: adım 16, 3 resimden 1. Wii U GamePad Motherboard Replacement: adım 16, 3 resimden 2. Wii U GamePad Motherboard Replacement: adım 16, 3 resimden 3.
    • Remove these two connectors to the motherboard with your fingers.
  17. Wii U GamePad Motherboard Replacement: adım 17, 2 resimden 1. Wii U GamePad Motherboard Replacement: adım 17, 2 resimden 2.
    • Remove the NFC communicator.
    • When removing the NFC communicator, be careful with the small connector on the back side.
    • Remove the small connector plug-in on the back.
  18. Wii U GamePad Motherboard Replacement: adım 18, 3 resimden 1. Wii U GamePad Motherboard Replacement: adım 18, 3 resimden 2. Wii U GamePad Motherboard Replacement: adım 18, 3 resimden 3.
    • Remove the remaining three 5.1 mm screws using the Phillips size #0 screwdriver.
    • Lift and remove the mother board.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Valentina Cerruty
3.455 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G6
4 Üyeler
40 adet Kılavuz yazıldı
2Kılavuz Yorumları
i need help with the tiny clasp for the touch glass ribbon. the tiny grey clasp snapped off and now the ribbon will not stay in, so i can't use the touch screen, if there a way to secure that tiny ribbon to the contact?
Roxanne - Yanıt
How can i see what version off motherboard i need to buy to replace it
I got 30X52504 as number on the board
VillainVibe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 42
Son 30 gün: 182
Her zaman: 17,649
