Ana içeriğe geç
Wii U GamePad Outer Case Replacement
Neye ihtiyacın var
  1. Wii U GamePad Outer Case Replacement, Battery: adım 1, 2 resimden 1. Wii U GamePad Outer Case Replacement, Battery: adım 1, 2 resimden 2.
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: adım 2, 3 resimden 1. Wii U GamePad Outer Case Replacement: adım 2, 3 resimden 2. Wii U GamePad Outer Case Replacement: adım 2, 3 resimden 3.
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: adım 3, 3 resimden 1. Wii U GamePad Outer Case Replacement, Outer Case: adım 3, 3 resimden 2. Wii U GamePad Outer Case Replacement, Outer Case: adım 3, 3 resimden 3.
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: adım 4, 2 resimden 1. Wii U GamePad Outer Case Replacement: adım 4, 2 resimden 2.
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Kim Arre
4.918 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G20
5 Üyeler
38 adet Kılavuz yazıldı
2 Yorum
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Yanıt
and the front?
Raul Kim Diego - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 35
Son 30 gün: 118
Her zaman: 14,624
