Ana içeriğe geç
Wii U GamePad Outer Case Replacement
Neye ihtiyacın var
  1. Wii U GamePad Outer Case Replacement, Battery: adım 1, 1 resimden 1.
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Outer Case Replacement: adım 2, 1 resimden 1.
    • Lift and remove the battery plate.
  3. Wii U GamePad Outer Case Replacement: adım 3, 3 resimden 1. Wii U GamePad Outer Case Replacement: adım 3, 3 resimden 2. Wii U GamePad Outer Case Replacement: adım 3, 3 resimden 3.
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
  4. Wii U GamePad Outer Case Replacement, Outer Case: adım 4, 3 resimden 1. Wii U GamePad Outer Case Replacement, Outer Case: adım 4, 3 resimden 2. Wii U GamePad Outer Case Replacement, Outer Case: adım 4, 3 resimden 3.
    • Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
    • Lift up on the back of case.
    • Lift gently because the rumble motor in the back of the case is still connected by a cable to the motherboard.
  5. Wii U GamePad Outer Case Replacement: adım 5, 1 resimden 1.
    • Unplug outer case rumble motor connector from the motherboard with your fingers.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Valentina Cerruty
3.345 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S1G6
4 Üyeler
40 adet Kılavuz yazıldı
2 Yorum
This doesn't show anything about taking the front of the housing off, is that relatively straightforward?
Will Prosser - Yanıt
This doesn't show anything about the L and R sticks like moving on its own when i play, do you how to fix that?
Victoria Gonzalez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 36
Son 30 gün: 177
Her zaman: 6,485
