Giriş
This guide will help you to replace the speakers if you are experiencing audio issues.
Neye ihtiyacın var
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
6 farklı kişi bu kılavuzu tamamladı.
