Ana içeriğe geç
Wiko Getaway Screen Panel Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Wiko Getaway Screen Panel Replacement, Back cover: adım 1, 3 resimden 1. Wiko Getaway Screen Panel Replacement, Back cover: adım 1, 3 resimden 2. Wiko Getaway Screen Panel Replacement, Back cover: adım 1, 3 resimden 3.
    • Broken screen ? that's a pity
    • You'll need hot air. Not too much thought, you'll melt the plastic otherwise
    • Now just pry it open SLOWLY and apply heat.
  2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: adım 2, 3 resimden 1. Wiko Getaway Screen Panel Replacement, Disconnect stuff: adım 2, 3 resimden 2. Wiko Getaway Screen Panel Replacement, Disconnect stuff: adım 2, 3 resimden 3.
    • Nice, I see you've got the cover off
    • Disconnect the battery (not with a metal tool)
    • Disconnect the touch screen ribbon (don't pull hard, you have to lift the plastic bit before)
  3. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: adım 3, 3 resimden 1. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: adım 3, 3 resimden 2. Wiko Getaway Screen Panel Replacement, Disconnecting more stuff: adım 3, 3 resimden 3.
    • Get the battery out (don't bend it too much)
    • Disconnect the LCD ribbon
    • Disconnect the cameras
  4. Wiko Getaway Screen Panel Replacement, Screws ! Finally: adım 4, 3 resimden 1. Wiko Getaway Screen Panel Replacement, Screws ! Finally: adım 4, 3 resimden 2. Wiko Getaway Screen Panel Replacement, Screws ! Finally: adım 4, 3 resimden 3.
    • Unscrew anything you see
    • Take the SIM trays out
    • Take the motherboard out. You will have to disconnect to ribbon cables
  5. Wiko Getaway Screen Panel Replacement, Final: adım 5, 3 resimden 1. Wiko Getaway Screen Panel Replacement, Final: adım 5, 3 resimden 2. Wiko Getaway Screen Panel Replacement, Final: adım 5, 3 resimden 3.
    • Two screws here
    • To take this guy out, you can use heat again
    • Aaaaand with more heat, you will get the screen panel out !
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Alexandre Isaac
2.985 İtibar
8 adet Kılavuz yazıldı
Ekip
The Repair Academy The Repair Academy üyesi
Business
1 Üye
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 33
Her zaman: 2,255
