Giriş
Winterization of the recreational vehicle so that it can spend the winter without problems
Steps to follow to be able to winterize a typical trailer.
The undersides of the trailers are only protected by a tarpaulin.
Items passing through this tarp leave openings for rodents or other insects
Patch those holes with duck tape
With a soft brush and a soap brush clean the exterior of the trailer
Make sure it's completely dry before bringing it indoors if that's what you're doing.
After the exterior cleaning, it is an ideal moment to rinse with plenty of water the bumper which also serves as a storage for the sewer pipe.
Thoroughly rinse the inner bumper
Thoroughly rinse the pipe
Leave everything to air dry for a day.
A good idea to suspend the pipe so that it drips completely
Put it all back in the bumper
Close the refrigerator by pressing OFF
Taking tea towels, place it at the bottom of the refrigerator and leave the door open
The next day, clean dry the inside
Place baking soda during hibernation
Place scraps of wood so that the freezer compartment can breathe and have air
If possible open the door ajar during hibernation
With a jet nozzle clean the toilet until no more deposits remain and your outlet water is clear
If you are not connected to a drain, you can use a bucket and gloves
The valves are placed in such a way as to allocate cold water into the water heater and out. The cold-hot junction valve is closed
Open valves to prevent cold water from entering and hot water from exiting. Open the cold-hot junction valve
To drain the water heater, the anode must be unscrewed with a 1 and 1/16 inch socket.
Release pressure by pressing the valve repeatedly
Unscrew the anode completely and let the water flow completely out of the water heater
The teflon tape will be to replace that of the anode next spring
Once empty replace the anode
Turn the valve down (for my system) and the pump will draw liquid from the food grade antifreeze container
Start the pump
Always one faucet at a time, start with the sink cold water stop when the antifreeze comes out fully pink
Continue with the hot water tap
Go use the toilet
Open bath cold water faucet, stop when antifreeze comes out
Do not forget to shower, water accumulates there.
Open hot water tap, stop when antifreeze comes out
Take the fire extinguisher, shake it to stir the powder inside
You can knock it lightly on a padded surface
Remove any type of fabric likely to be undone by mice or rodents: tissues, paper towels, etc.
Finally, place Bounce sheets under mattresses and other pillows.
Placed in places near an exterior mouth keep mice and other rodents away with their scent
Disassemble the tank, tie the wires securely so they don't hang or catch anything along the way.
Burn the excess gas via the rings, the fridge, the water heater. As soon as the flame starter clicks stop
Close the circuit breakers so as not to draw all the energy from the battery of the towing vehicle during the trip to storage
Disconnect the battery and store it out of the gel on a wooden or plastic surface. Anything but concrete. Recharge the battery once or twice during the winter and before leaving with the trailer
Tie the battery wires securely
Open drain plugs to remove excess water
Possibility of leaving things that do not fear the cold. Plastic tips, empty and dry pipes, tools, etc.
Lock all compartments and doors.
Leave interior doors open during hibernation
If a Max-Air is present leave a very small gap on the roof vent
In spring the steps are almost the opposite
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
