Ana içeriğe geç
Window Operator Link Replacement
Neye ihtiyacın var
  1. Window Operator Link Replacement, Link: adım 1, 2 resimden 1. Window Operator Link Replacement, Link: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Flathead 4 mm Screwdriver
    $5.49
    Satın Al
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: adım 2, 3 resimden 1. Window Operator Link Replacement: adım 2, 3 resimden 2. Window Operator Link Replacement: adım 2, 3 resimden 3.
    Large Needle Nose Pliers
    Satın Al
  3. Window Operator Link Replacement: adım 3, 3 resimden 1. Window Operator Link Replacement: adım 3, 3 resimden 2. Window Operator Link Replacement: adım 3, 3 resimden 3.
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: adım 4, 3 resimden 1. Window Operator Link Replacement: adım 4, 3 resimden 2. Window Operator Link Replacement: adım 4, 3 resimden 3.
    Metal Spudger
    $2.99
    Satın Al
  5. Window Operator Link Replacement: adım 5, 3 resimden 1. Window Operator Link Replacement: adım 5, 3 resimden 2. Window Operator Link Replacement: adım 5, 3 resimden 3.
    Satın Al
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
Sonuç
To reassemble your device, follow from step three (3) to one (1) in reverse order.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 55
Her zaman: 830
