Ana içeriğe geç
Window Operator Link Replacement
Neye ihtiyacın var
    1. Window Operator Link Replacement, Link: adım 1, 2 resimden 1. Window Operator Link Replacement, Link: adım 1, 2 resimden 2.
      Bu adımda kullanılan alet:
      Flathead 4 mm Screwdriver
      $1.99
      • Remove the four (4) window clips that holds the screen.
      • Your amount of window clips may vary depending on the size of your window.
      • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
      • Remove the screen and put it aside.
      FixBot'a Sor
      Yorum Ekle
    2. Window Operator Link Replacement: adım 2, 3 resimden 1. Window Operator Link Replacement: adım 2, 3 resimden 2. Window Operator Link Replacement: adım 2, 3 resimden 3.
      Metal Spudger
      $2.99
      • Remove e-clip from the window link, use the [bağlı ürün eksik veya kapalı: IF145-024] to remove it.
      • If the e-clip is stuck, you can use a Metal Spudger or a Flathead 4 mm Screwdriver to force it out.
      FixBot'a Sor
      Yorum Ekle
    3. Window Operator Link Replacement: adım 3, 3 resimden 1. Window Operator Link Replacement: adım 3, 3 resimden 2. Window Operator Link Replacement: adım 3, 3 resimden 3.
      • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
      • Behind the window, you will have one self retaining nut per bolt.
      • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
      FixBot'a Sor
      Yorum Ekle
    4. Window Operator Link Replacement: adım 4, 3 resimden 1. Window Operator Link Replacement: adım 4, 3 resimden 2. Window Operator Link Replacement: adım 4, 3 resimden 3.
      Metal Spudger
      $2.99
      FixBot'a Sor
      Yorum Ekle
    5. Window Operator Link Replacement: adım 5, 3 resimden 1. Window Operator Link Replacement: adım 5, 3 resimden 2. Window Operator Link Replacement: adım 5, 3 resimden 3.
      • Once the warped or broken link is removed, follow the Step 4 in reverse order.
      • You may use the [bağlı ürün eksik veya kapalı: IF145-024] to force the e-clip into place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow from step three (3) to one (1) in reverse order.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 41
Son 30 gün: 135
Her zaman: 2,536
