Giriş
The purpose of a window screen is to prevent bugs, leaves, birds, etc., from getting into the house. However, when a screen has tears and holes in it, the screen is no longer helpful in keeping those things out. This guide provides instructions for replacing the screen mesh on the window screen frame so it will be as good as new and be a helpful protection to the inside of the house again.
Before beginning this repair, make sure that the screen mesh is big enough to go over the whole frame. Also, this repair is best to do on a flat surface, like a table.
Neye ihtiyacın var
Find the place in the channel of the screen frame where the ends of the spline meet.
Use a screwdriver to pry out an end of the spline.
After removing a couple inches of the spline, hold the spline with a hand and pull all of the spline out of the channel.
If the screen mesh isn't tight enough or there are other issues, return to the beginning of the steps and restart. You don't have to do all of the steps if you are doing a minor revision, however, like only taking the spline out in order to tighten the screen mesh and placing the spline back afterwards.
Bir başkası bu kılavuzu tamamladı.
