Ana içeriğe geç
Windsor Willow Chain Replacement
  1. Windsor Willow Chain Replacement, Chain: adım 1, 1 resimden 1.
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Chain Replacement: adım 2, 1 resimden 1.
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Chain Replacement: adım 3, 2 resimden 1. Windsor Willow Chain Replacement: adım 3, 2 resimden 2.
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Chain Replacement: adım 4, 1 resimden 1.
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stuart Ross
225 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G6
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 87
