Ana içeriğe geç
Windsor Willow Crankshaft Replacement
Neye ihtiyacın var
  1. Windsor Willow Crankshaft Replacement, Chain: adım 1, 1 resimden 1.
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Crankshaft Replacement: adım 2, 1 resimden 1.
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Crankshaft Replacement: adım 3, 2 resimden 1. Windsor Willow Crankshaft Replacement: adım 3, 2 resimden 2.
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Crankshaft Replacement: adım 4, 1 resimden 1.
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Crankshaft Replacement, Crankshaft: adım 5, 1 resimden 1.
    • The crank arms can be located between the front and rear tire, directly below the seat.
  6. Windsor Willow Crankshaft Replacement: adım 6, 1 resimden 1.
    • To remove the crank arm, place a proper fitting Allen wrench into the slot at the center of the crank arm as shown. Turn the wrench counterclockwise to loosen the bolt that keeps the crank arm on the bike until it spins easily. Hold the other crank arm in place to ensure that the bolt loosens instead of spinning the crank arm.
  7. Windsor Willow Crankshaft Replacement: adım 7, 1 resimden 1.
    • Once the bolt spins easily, keep the Allen wrench in the bolt slot and turn the crank arms to speed up the removal process.
  8. Windsor Willow Crankshaft Replacement: adım 8, 1 resimden 1.
    • Remove the bolt from the crank arm. The crank arm will remain in place. Do not try to pull off the crank arm, as a special tool is required for this task.
  9. Windsor Willow Crankshaft Replacement: adım 9, 3 resimden 1. Windsor Willow Crankshaft Replacement: adım 9, 3 resimden 2. Windsor Willow Crankshaft Replacement: adım 9, 3 resimden 3.
    • Repeat steps 2-4 on the other crank arm. Remember, do not try to pull off the crank arms.
  10. Windsor Willow Crankshaft Replacement: adım 10, 1 resimden 1.
    • Obtain a crank puller tool. This tool has two parts, a movable threaded insert and the push bolt. Screw the crank puller into the hole left by the bolt.
    • Be sure to be gentle and thread the first few turns by hand as to not accidentally cross thread your crankarms.
  11. Windsor Willow Crankshaft Replacement: adım 11, 3 resimden 1. Windsor Willow Crankshaft Replacement: adım 11, 3 resimden 2. Windsor Willow Crankshaft Replacement: adım 11, 3 resimden 3.
    • Once the movable piece is tightened firmly inside the hole, turn the tool clockwise. This will pull the crank arm away from the bike and remove it completely.
  12. Windsor Willow Crankshaft Replacement: adım 12, 3 resimden 1. Windsor Willow Crankshaft Replacement: adım 12, 3 resimden 2. Windsor Willow Crankshaft Replacement: adım 12, 3 resimden 3.
    • Repeat steps 6-7 with the remaining crank arm. Both arms have been successfully removed.
Sonuç
Stuart Ross
225 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S10G6
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 128
