Ana içeriğe geç
Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement
Neye ihtiyacın var
  1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement, HEPA Filter: adım 1, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement, HEPA Filter: adım 1, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement, HEPA Filter: adım 1, 3 resimden 3.
    • Remove the air intake cover by placing your hands at the top of the air intake cover and gently pulling away from the device.
    • You can choose to unplug or leave the device plugged in. Either way, it will not affect the process.
  2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 2, 2 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 2, 2 resimden 2.
    • Using your vacuum, clean the air intake screen.
    • Any vacuum and any attachment that has a brush will work for cleaning the air intake screen.
  3. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 3, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 3, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 3, 3 resimden 3.
    • Detach the air intake screen by placing your fingers on the top two hinges.
    • Gently press the two hinges down and pull away from the device.
    • Using your vacuum, clean the other side of the air intake screen.
  4. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 4, 2 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 4, 2 resimden 2.
    • Remove the Activated Carbon Pre-Filter by pulling it away from the device.
    • Throw away the Activated Carbon Pre-Filter into a garbage can.
  5. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 5, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 5, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 5, 3 resimden 3.
    • Remove the True HEPA Filter by pulling it away from the device.
    • Throw away the True HEPA Filter into a garbage can.
  6. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 6, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 6, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 6, 3 resimden 3.
    • Replace the True HEPA Filter by inserting it into the empty space in the device.
    • The arrow on the top of the True HEPA Filter should point towards the device and away from you.
  7. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 7, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 7, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 7, 3 resimden 3.
    • Replace the Activated Carbon Pre-Filter by inserting it into the space in front of the True HEPA Filter.
  8. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 8, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 8, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 8, 3 resimden 3.
    • Attach the air intake screen by placing the bottom two hinges in the bottom two holes of the device.
    • Using your fingers, gently press down on the top two hinges while placing them in the top two holes of the device.
  9. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 9, 3 resimden 1. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 9, 3 resimden 2. Winix C535 Air Cleaner with PlasmaWave Technology HEPA Filter Replacement: adım 9, 3 resimden 3.
    • Attach the air intake cover by gently pressing the top of the cover against the device.
Sonuç
You have now replaced the HEPA Filter to continue purifying the air.
7 farklı kişi bu kılavuzu tamamladı.
[deleted]
379 İtibar
1 Kılavuz yazıldı
5 Yorum
Very easy to replace. Breeze.
Alex Parson - Yanıt
@tackerman Where can I get a replacement air intake screen (the mesh ‘Pre-Filter’?) Mine has a tear in it and I can't find a replacement anywhere online. Thanks!
Aftab Khan - Yanıt
You can just scotch tape the tear (from two sides) if it is not too big
Anwar Ben Tanfous -
My Winix C535 came with two air filters. This video should only shows one. So is it supposed to have two filters inserted?
Ray Hill - Yanıt
No, it's likely yours came with an extra replacement filter with the purchase. Their should only be one HEPA filter followed by one carbon filter and then lastly the mesh pre filter screen that locks into place.
JASON UNDERWOOD -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 84
Her zaman: 13,458
