Ana içeriğe geç
Wintec Filemate Clear 7" Battery Replacement
Neye ihtiyacın var
  1. Wintec Filemate Clear 7" Battery Replacement, Remove the Backplate: adım 1, 1 resimden 1.
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Battery Replacement: adım 2, 2 resimden 1. Wintec Filemate Clear 7" Battery Replacement: adım 2, 2 resimden 2.
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Battery Replacement, Remove the Battery: adım 3, 1 resimden 1.
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Battery Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Battery Replacement: adım 5, 1 resimden 1.
    • Fully remove the battery from the device.
Sonuç
To reassemble your device, glue the new battery to where the old one was and solder the new power connectors where the old ones were. Then follow the instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Nicholas Ferraro
431 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014 üyesi
USFT-BLACKWELL-S14S19G6
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,105
