Ana içeriğe geç
Wintec Filemate Clear 7" Charging Pin Replacement
    1. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Backplate: adım 1, 1 resimden 1.
      • Locate the four corners of the backplate.
      FixBot'a Sor
      Yorum Ekle
    2. Wintec Filemate Clear 7" Charging Pin Replacement: adım 2, 2 resimden 1. Wintec Filemate Clear 7" Charging Pin Replacement: adım 2, 2 resimden 2.
      • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
      FixBot'a Sor
      Yorum Ekle
    1. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Battery: adım 3, 1 resimden 1.
      • Un-stick the battery from the motherboard assembly with the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Wintec Filemate Clear 7" Charging Pin Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Desolder the battery wires from the motherboard.
      • The tweezers pictured point to the two solder joints.
      FixBot'a Sor
      Yorum Ekle
    3. Wintec Filemate Clear 7" Charging Pin Replacement: adım 5, 1 resimden 1.
      • Fully remove the battery from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Wintec Filemate Clear 7" Charging Pin Replacement, Motherboard: adım 6, 1 resimden 1.
      • Locate each of the motherboard's 4 mm screws.
      FixBot'a Sor
      Yorum Ekle
    2. Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: adım 7, 3 resimden 1. Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: adım 7, 3 resimden 2. Wintec Filemate Clear 7" Charging Pin Replacement, Unscrewing Everything: adım 7, 3 resimden 3.
      • Remove each of the four 4 mm screws from the motherboard pictured to the left.
      • Use a Phillips #00 precision screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Wintec Filemate Clear 7" Charging Pin Replacement, Detach the Motherboard: adım 8, 2 resimden 1. Wintec Filemate Clear 7" Charging Pin Replacement, Detach the Motherboard: adım 8, 2 resimden 2.
      • Use the spudger to pry the instrument array from its plastic housing.
      FixBot'a Sor
      Yorum Ekle
    4. Wintec Filemate Clear 7" Charging Pin Replacement: adım 9, 1 resimden 1.
      • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
      • Be careful not to harm the array of wires leading to this tape.
      FixBot'a Sor
      Yorum Ekle
    5. Wintec Filemate Clear 7" Charging Pin Replacement: adım 10, 1 resimden 1.
      • De-tatch the motherboard output wires from the screen using the tweezers.
      FixBot'a Sor
      Yorum Ekle
    1. Wintec Filemate Clear 7" Charging Pin Replacement, Remove the Charging Pin: adım 11, 1 resimden 1.
      • Remove the charging pin holster.
      • Clamp on the end of the holster with the tweezers and twist until it becomes detached.
      • Repeat for the other side.
      FixBot'a Sor
      Yorum Ekle
    2. Wintec Filemate Clear 7" Charging Pin Replacement: adım 12, 1 resimden 1.
      • Clamp onto the charging pin and twist up until it pops out of place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. The charging pin holster needs to be soldered back into place.
Bir başkası bu kılavuzu tamamladı.
Nicholas Ferraro
431 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014 üyesi
USFT-BLACKWELL-S14S19G6
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 336
