Ana içeriğe geç
Wintec Filemate Clear 7" Motherboard Replacement
Neye ihtiyacın var
  1. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Backplate: adım 1, 1 resimden 1.
    • Locate the four corners of the backplate.
  2. Wintec Filemate Clear 7" Motherboard Replacement: adım 2, 2 resimden 1. Wintec Filemate Clear 7" Motherboard Replacement: adım 2, 2 resimden 2.
    • Pry off the backplate by inserting a spudger or plastic opening tool into each corner and popping them open.
  3. Wintec Filemate Clear 7" Motherboard Replacement, Remove the Battery: adım 3, 1 resimden 1.
    • Un-stick the battery from the motherboard assembly with the plastic opening tool.
  4. Wintec Filemate Clear 7" Motherboard Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Desolder the battery wires from the motherboard.
    • The tweezers pictured point to the two solder joints.
  5. Wintec Filemate Clear 7" Motherboard Replacement: adım 5, 1 resimden 1.
    • Fully remove the battery from the device.
  6. Wintec Filemate Clear 7" Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Locate each of the motherboard's 4 mm screws.
  7. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: adım 7, 3 resimden 1. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: adım 7, 3 resimden 2. Wintec Filemate Clear 7" Motherboard Replacement, Unscrewing Everything: adım 7, 3 resimden 3.
    • Remove each of the four 4 mm screws from the motherboard pictured to the left.
    • Use a Phillips #00 precision screwdriver.
  8. Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: adım 8, 2 resimden 1. Wintec Filemate Clear 7" Motherboard Replacement, Detach the Motherboard: adım 8, 2 resimden 2.
    • Use the spudger to pry the instrument array from its plastic housing.
  9. Wintec Filemate Clear 7" Motherboard Replacement: adım 9, 1 resimden 1.
    • Slowly slide the spudger underneath the adhesive tape to un-sitck it.
    • Be careful not to harm the array of wires leading to this tape.
  10. Wintec Filemate Clear 7" Motherboard Replacement: adım 10, 1 resimden 1.
    • De-tatch the motherboard output wires from the screen using the tweezers.
Sonuç
Nicholas Ferraro
431 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-6, Blackwell Spring 2014 USF Tampa, Team 19-6, Blackwell Spring 2014 üyesi
USFT-BLACKWELL-S14S19G6
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 174
