Ana içeriğe geç
Wire Bonder Thread Spool Replacement
Videoya Genel Bakış
  1. Wire Bonder Thread Spool Replacement, Wire Bonder Thread Spool Replacement: adım 1, 1 resimden 1.
    • Remove the seal from the wire spool. Take care not to cut the thread at the red marking!
    FixBot'a Sor
    Yorum Ekle
  2. Wire Bonder Thread Spool Replacement: adım 2, 1 resimden 1.
    • Insert the spool in the assembly.
    • Make sure that the spool runs clockwise.
    FixBot'a Sor
    Yorum Ekle
    • Pull the thread downward.
    FixBot'a Sor
    Yorum Ekle
  3. Wire Bonder Thread Spool Replacement, Placing the thread into the infeeder: adım 4, 1 resimden 1.
    • Place the thread between the guides of the infeeder.
    • Pull the engaging knob which is situated to the left of the infeeder rolls, to the left.
    • Now there is a gap between the infeeder rolls into which the wire can be inserted safely.
    FixBot'a Sor
    Yorum Ekle
  4. Wire Bonder Thread Spool Replacement, Placing the thread behind the sensors: adım 5, 1 resimden 1.
    • Cut the wire.
    • Place the wire behind the sensors (the black box in the foreground).
    FixBot'a Sor
    Yorum Ekle
  5. Wire Bonder Thread Spool Replacement, Placing the thrad in the outfeeder: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to place the wire between the two metal guides of the outfeeder.
    FixBot'a Sor
    Yorum Ekle
  6. Wire Bonder Thread Spool Replacement, Put the wire into the tube: adım 7, 1 resimden 1.
    • Use the tweezers to lead the wire into the tube from below.
    FixBot'a Sor
    Yorum Ekle
  7. Wire Bonder Thread Spool Replacement, Automatic feeding: adım 8, 1 resimden 1.
    • Push the spring of the outfeeder and the "Feed and Capture" button simultaneously for automatic feeding.
    • Make sure that the rolls of the outfeeder are close together so that the wire is gripped firmly.
    • Before starting automatic feeding, turn off "Run or Service" and activate "Feed or Capture".
    FixBot'a Sor
    Yorum Ekle
  8. Wire Bonder Thread Spool Replacement, Manual Feeding: adım 9, 2 resimden 1. Wire Bonder Thread Spool Replacement, Manual Feeding: adım 9, 2 resimden 2.
    • It is also possible to feed the wire manually into the outfeeder tube.
    • In order to do so, press the "Run and Service" button and turn the left-hand wheel clockwise. The wire is now fed ino the tube.
    FixBot'a Sor
    Yorum Ekle
  9. Wire Bonder Thread Spool Replacement: adım 10, 1 resimden 1.
    • Check visually if the wire is fed into the bonding head.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Beate Richter
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 348
