Ana içeriğe geç
Wire Stripping
Neye ihtiyacın var
    1. Wire Stripping, Wire Stripping: adım 1, 1 resimden 1.
      • Match your gauge of wire to the gauge on a wire stripper.
      • Some wire strippers will have two gauge sizes for the same hole, one for solid wire and one for stranded. Make sure you use the right one for the wire you are stripping!
      FixBot'a Sor
      Yorum Ekle
    2. Wire Stripping: adım 2, 1 resimden 1.
      • Place the wire stripper about a 1/4” from the end of the wire and squeeze down.
      • You can strip more than 1/4" at a time, but the effort becomes harder. About 1/2-5/8" (13-16 mm) is the most you should probably attempt.
      FixBot'a Sor
      Yorum Ekle
    3. Wire Stripping: adım 3, 1 resimden 1.
      • While squeezing, pull the stripper toward the end of the wire. This should expose some of the wire by removing its insulation.
      FixBot'a Sor
      Yorum Ekle
Sonuç
After your wire has been stripped, the exposed wire is ready to be soldered and reconnected to other parts of the microphone.
23 farklı kişi bu kılavuzu tamamladı.
nat coll
859 İtibar
14 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-53, Forte Fall 2012 Cal Poly, Team 7-53, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G53
5 Üyeler
61 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 66
Son 30 gün: 341
Her zaman: 13,166
