Ana içeriğe geç
Wireless LAN card Replacement
  1. Wireless LAN card Replacement, Back Panel: adım 1, 2 resimden 1. Wireless LAN card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Wireless LAN card Replacement: adım 2, 2 resimden 1. Wireless LAN card Replacement: adım 2, 2 resimden 2.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  3. Wireless LAN card Replacement, Wireless LAN card: adım 3, 1 resimden 1.
    • Use the tweezers to remove the two connecting wires.
  4. Wireless LAN card Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the two 2.5mm screws holding down the card.
  5. Wireless LAN card Replacement: adım 5, 1 resimden 1.
    • Lift and pull the Wireless LAN card away from the computer.
Sonuç
Armani Tayeh
432 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Peak Spring 2018 UMass Dartmouth, Team S3-G2, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G2
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 338
