Ana içeriğe geç
Withings Smart Body Analyzer Motherboard Replacement
Neye ihtiyacın var
  1. Withings Smart Body Analyzer Motherboard Replacement, Withings Smart Body Analyzer Disassembly: adım 1, 1 resimden 1.
    • Push the battery door
    • Open the compartment
    • Gently remove the batteries from their designated positions
    • Place them aside, away from the reach of children
    FixBot'a Sor
    Yorum Ekle
  2. Withings Smart Body Analyzer Motherboard Replacement: adım 2, 3 resimden 1. Withings Smart Body Analyzer Motherboard Replacement: adım 2, 3 resimden 2. Withings Smart Body Analyzer Motherboard Replacement: adım 2, 3 resimden 3.
    • With caution, insert the plastic opening tools in between the disk and the glass face
    • It's a tight fit, so don't be afraid to apply a little bit of force
    • As soon as you hear a faint crackling sound, that means that the adhesive is budging out of place
    • Gently rotate the plastic spudger around the disk to get around the adhesive
    • Gently lift the metal disk
    • After the disk has been lifted, a wire and a small copper plate can be seen attached to the back of the disk
    • Carefully remove the wire and plate by peeling back the adhesive sticker that has been positioned around them
    FixBot'a Sor
    Yorum Ekle
  3. Withings Smart Body Analyzer Motherboard Replacement: adım 3, 2 resimden 1. Withings Smart Body Analyzer Motherboard Replacement: adım 3, 2 resimden 2.
    • After all the above steps have been completed, proceed by removing the glass face
    • Carefully insert a plasic spudger in the small gap that exist in between the glass face and the plastic back
    • Run the plastic spudger all around the scale to increase the gap size
    • Place a plastic spudger in every corner, since the feet of the scale are also attached to the glass face using adhesive
    • Carefully insert the metal spudger underneath the adhesive that is located underneath the feet of the scale, and gently keep pushing until the adhesive is out of place
    • Repeat the above steps four times
    • After all the adhesives has been removed, gently lift the glass face off
    FixBot'a Sor
    Yorum Ekle
  4. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Withings Smart Body Analyzer Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using the Phillips-head screwdriver, unscrew the two screws that are securing the motherboard in place
    FixBot'a Sor
    Yorum Ekle
  5. Withings Smart Body Analyzer Motherboard Replacement: adım 5, 1 resimden 1.
    • Using a plastic spudger, disconnect the LCD display's ribbon cable from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Withings Smart Body Analyzer Motherboard Replacement: adım 6, 1 resimden 1.
    • Once the two screws and the ribbon cable are detached, remove the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ashley Dauphinee
323 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Julie Spring 2017 UMass Dartmouth, Team S4-G1, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S4G1
4 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
My Wifi Body scale cannot connect to Wifi or my app. Everything else works. Where can I have it repaired. Please advise.
Mel - Yanıt Paylaş
where do you get the motherboard?
cost?
donald taylor - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 24
Son 30 gün: 112
Her zaman: 7,989
