Ana içeriğe geç
Wolf Gourmet WGTR102S Electrical Connection Replacement
Neye ihtiyacın var
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Outer Shell: adım 1, 1 resimden 1.
      • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
      FixBot'a Sor
      Yorum Ekle
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 2, 1 resimden 1.
      • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 3, 1 resimden 1.
      • Remove the crumb collector located on the bottom of the toaster.
      FixBot'a Sor
      Yorum Ekle
    4. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 4, 1 resimden 1.
      • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 5, 1 resimden 1.
      • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
      • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
      FixBot'a Sor
      Yorum Ekle
    6. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 6, 1 resimden 1.
      • Remove the final 8mm screw in the slide lever.
      • The lever can now pull away from the entire unit.
      FixBot'a Sor
      Yorum Ekle
    7. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 7, 1 resimden 1.
      • Remove toaster's outer shell by lifting straight up.
      • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
      FixBot'a Sor
      Yorum Ekle
    8. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 8, 2 resimden 1. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 8, 2 resimden 2.
      • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
      • Remove the outer shell from the device.
      FixBot'a Sor
      Yorum Ekle
    1. Wolf Gourmet WGTR102S Electrical Connection Replacement, Electrical Connection: adım 9, 1 resimden 1.
      • Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
      FixBot'a Sor
      Yorum Ekle
    2. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 10, 1 resimden 1.
      • Use pliers to pull apart the three electrical connectors pictured in the graphic.
      FixBot'a Sor
      Yorum Ekle
    3. Wolf Gourmet WGTR102S Electrical Connection Replacement: adım 11, 1 resimden 1.
      • Replace the electrical connectors.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Funchess
715 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G5, Maness Spring 2018 Cal Poly, Team S22-G5, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G5
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Ryan Funchess
Thank you for you work on this toaster. My customer is happy.
Adam Hunsinger - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 39
Her zaman: 1,399
