Ana içeriğe geç
Wolf Gourmet WGTR102S Outer Shell Replacement
Neye ihtiyacın var
  1. Wolf Gourmet WGTR102S Outer Shell Replacement, Outer Shell: adım 1, 1 resimden 1.
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 2, 1 resimden 1.
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 3, 1 resimden 1.
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 4, 1 resimden 1.
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 5, 1 resimden 1.
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 6, 1 resimden 1.
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 7, 1 resimden 1.
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 8, 2 resimden 1. Wolf Gourmet WGTR102S Outer Shell Replacement: adım 8, 2 resimden 2.
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan Funchess
697 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G5, Maness Spring 2018 Cal Poly, Team S22-G5, Maness Spring 2018 üyesi
CPSU-MANESS-S18S22G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 550
