Ana içeriğe geç
Wolfgang Puck Pie Maker Disassembly
Neye ihtiyacın var
  1. Wolfgang Puck Pie Maker Disassembly, Wolfgang Puck Pie Maker Disassembly: adım 1, 1 resimden 1.
    • Open up the pie maker using the two main handles so it's open as shown in the picture.
  2. Wolfgang Puck Pie Maker Disassembly: adım 2, 2 resimden 1. Wolfgang Puck Pie Maker Disassembly: adım 2, 2 resimden 2.
    • Remove the four 12.7 mm screws from each handle using a Phillips #2 screwdriver.
    • Remove the inside handle cover.
  3. Wolfgang Puck Pie Maker Disassembly: adım 3, 2 resimden 1. Wolfgang Puck Pie Maker Disassembly: adım 3, 2 resimden 2.
    • Remove the two 12.7 mm screws from the base of the pie maker using a Phillips #2 screwdriver.
    • This will allow for visibility into the wiring in the base.
  4. Wolfgang Puck Pie Maker Disassembly: adım 4, 2 resimden 1. Wolfgang Puck Pie Maker Disassembly: adım 4, 2 resimden 2.
    • Remove the four 15.9 mm screws from the hinges using a Phillips #2 screwdriver.
    • Remove the top cover by pulling it off of the device.
  5. Wolfgang Puck Pie Maker Disassembly: adım 5, 2 resimden 1. Wolfgang Puck Pie Maker Disassembly: adım 5, 2 resimden 2.
    • You now have access to the wiring underneath the top and bottom of the device.
    • To access the wiring, lift the metal burner part out of the base. The wiring will be visible on the opposite side, attached to the heating coil.
    • The temperature sensor can be accessed by lifting the bottom side of the device as shown.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 189
