Ana içeriğe geç
Wood Stool Leg Glide Replacement
Neye ihtiyacın var
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: adım 1, 1 resimden 1.
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: adım 2, 1 resimden 1.
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: adım 3, 1 resimden 1.
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: adım 4, 1 resimden 1.
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: adım 5, 1 resimden 1.
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: adım 6, 1 resimden 1.
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: adım 7, 2 resimden 1. Wood Stool Leg Glide Replacement: adım 7, 2 resimden 2.
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 375
