Ana içeriğe geç
World Dryer Airforce J4-973A3 Sensor Board Replacement
Neye ihtiyacın var
  1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: adım 1, 3 resimden 1. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: adım 1, 3 resimden 2. World Dryer Airforce J4-973A3 Sensor Board Replacement, Sensor Board: adım 1, 3 resimden 3.
    • In order to change the air filter, start with the removal of the outer metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 2, 3 resimden 1. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 2, 3 resimden 2. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 2, 3 resimden 3.
    • Remove the 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the unit.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a plastic opening tool.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 3, 2 resimden 1. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 3, 2 resimden 2.
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 4, 3 resimden 1. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 4, 3 resimden 2. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 4, 3 resimden 3.
    • Remove the rainbow ribbon cable from the middle circuit board, using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  5. World Dryer Airforce J4-973A3 Sensor Board Replacement: adım 5, 1 resimden 1.
    • Carefully remove the sensor board from your device.
Sonuç
Luke Clancy
123 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 616
