Ana içeriğe geç
World Dryer Airforce J4-973A3 Server Board Replacement
Neye ihtiyacın var
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: adım 1, 3 resimden 1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: adım 1, 3 resimden 2. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: adım 1, 3 resimden 3.
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: adım 2, 2 resimden 1. World Dryer Airforce J4-973A3 Server Board Replacement: adım 2, 2 resimden 2.
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: adım 3, 3 resimden 1. World Dryer Airforce J4-973A3 Server Board Replacement: adım 3, 3 resimden 2. World Dryer Airforce J4-973A3 Server Board Replacement: adım 3, 3 resimden 3.
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: adım 4, 3 resimden 1. World Dryer Airforce J4-973A3 Server Board Replacement: adım 4, 3 resimden 2. World Dryer Airforce J4-973A3 Server Board Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Sonuç
Blane Hirsh
260 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 247
