Ana içeriğe geç
WowWee CHiP Robot Dog Ear Replacement
Neye ihtiyacın var
  1. WowWee CHiP Robot Dog Ear Replacement, Battery: adım 1, 1 resimden 1.
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Ear Replacement: adım 2, 2 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 2, 2 resimden 2.
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Ear Replacement: adım 3, 2 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 3, 2 resimden 2.
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Ear Replacement: adım 4, 3 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 4, 3 resimden 2. WowWee CHiP Robot Dog Ear Replacement: adım 4, 3 resimden 3.
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Ear Replacement, Ear: adım 5, 2 resimden 1. WowWee CHiP Robot Dog Ear Replacement, Ear: adım 5, 2 resimden 2.
    • Remove the 4 Phillips screws shown.
  6. WowWee CHiP Robot Dog Ear Replacement: adım 6, 3 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 6, 3 resimden 2. WowWee CHiP Robot Dog Ear Replacement: adım 6, 3 resimden 3.
    • Pull up top part of toy and remove the connecting wires.
    • Unscrew the 2 Phillips head screws. CHiP should be viewed as seen in the third picture.
  7. WowWee CHiP Robot Dog Ear Replacement: adım 7, 3 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 7, 3 resimden 2. WowWee CHiP Robot Dog Ear Replacement: adım 7, 3 resimden 3.
    • Remove the 4 Phillips screws to separate the head from the body.
  8. WowWee CHiP Robot Dog Ear Replacement: adım 8, 2 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 8, 2 resimden 2.
    • Remove the 4 Phillips screws on back of the head, and pull off the casing for the back of the head.
  9. WowWee CHiP Robot Dog Ear Replacement: adım 9, 3 resimden 1. WowWee CHiP Robot Dog Ear Replacement: adım 9, 3 resimden 2. WowWee CHiP Robot Dog Ear Replacement: adım 9, 3 resimden 3.
    • Unscrew the screw on the ear with a Phillips screwdriver, and pull off the plastic connector. Remove the ear from head.
Sonuç
Bir Yorum
It’s almost a disassembly, probably quite hard to do. I did disassemble a MiPosaur, but some parts broke off. (!!!)
Michael Deitz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,517
