Ana içeriğe geç
WowWee CHiP Robot Dog Wheel Replacement
Neye ihtiyacın var
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: adım 1, 1 resimden 1.
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: adım 2, 2 resimden 1. WowWee CHiP Robot Dog Wheel Replacement: adım 2, 2 resimden 2.
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: adım 3, 2 resimden 1. WowWee CHiP Robot Dog Wheel Replacement: adım 3, 2 resimden 2.
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: adım 4, 3 resimden 1. WowWee CHiP Robot Dog Wheel Replacement: adım 4, 3 resimden 2. WowWee CHiP Robot Dog Wheel Replacement: adım 4, 3 resimden 3.
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: adım 5, 1 resimden 1.
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: adım 6, 1 resimden 1.
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: adım 7, 1 resimden 1.
    • Pull and remove wheel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Yanıt
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 3,915
