Ana içeriğe geç
WowWee MiP Robot Speaker Replacement
Neye ihtiyacın var
  1. WowWee MiP Robot  Speaker Replacement, Battery: adım 1, 2 resimden 1. WowWee MiP Robot  Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot  Speaker Replacement: adım 2, 2 resimden 1. WowWee MiP Robot  Speaker Replacement: adım 2, 2 resimden 2.
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot  Speaker Replacement, Wheel: adım 3, 2 resimden 1. WowWee MiP Robot  Speaker Replacement, Wheel: adım 3, 2 resimden 2.
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot  Speaker Replacement: adım 4, 2 resimden 1. WowWee MiP Robot  Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot  Speaker Replacement: adım 5, 1 resimden 1.
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot  Speaker Replacement, WowWee MiP Robot Body Disassembly: adım 6, 2 resimden 1. WowWee MiP Robot  Speaker Replacement, WowWee MiP Robot Body Disassembly: adım 6, 2 resimden 2.
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot  Speaker Replacement: adım 7, 3 resimden 1. WowWee MiP Robot  Speaker Replacement: adım 7, 3 resimden 2. WowWee MiP Robot  Speaker Replacement: adım 7, 3 resimden 3.
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot  Speaker Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot  Speaker Replacement, Speaker: adım 9, 2 resimden 1. WowWee MiP Robot  Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Remove the two 7.5 mm Phillips #1 screws holding the speaker bracket in place.
  10. WowWee MiP Robot  Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the plastic bracket covering the speaker.
  11. WowWee MiP Robot  Speaker Replacement: adım 11, 1 resimden 1.
    • Gently remove the speaker from the MiP.
    • During reassembly, be sure to place the speaker in the same position.
Sonuç
Daniel Burkholder
623 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-4, Wollert Spring 2016 USF Tampa, Team 3-4, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 527
