Ana içeriğe geç
WowWee MiP Robot Tire Replacement
Neye ihtiyacın var
  1. WowWee MiP Robot Tire Replacement, Wheel: adım 1, 2 resimden 1. WowWee MiP Robot Tire Replacement, Wheel: adım 1, 2 resimden 2.
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    FixBot'a Sor
    Yorum Ekle
  2. WowWee MiP Robot Tire Replacement: adım 2, 2 resimden 1. WowWee MiP Robot Tire Replacement: adım 2, 2 resimden 2.
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
    FixBot'a Sor
    Yorum Ekle
  3. WowWee MiP Robot Tire Replacement: adım 3, 1 resimden 1.
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
    FixBot'a Sor
    Yorum Ekle
  4. WowWee MiP Robot Tire Replacement, Tires: adım 4, 2 resimden 1. WowWee MiP Robot Tire Replacement, Tires: adım 4, 2 resimden 2.
    • Remove the three 7.7 mm Phillips #1 screws.
    FixBot'a Sor
    Yorum Ekle
  5. WowWee MiP Robot Tire Replacement: adım 5, 3 resimden 1. WowWee MiP Robot Tire Replacement: adım 5, 3 resimden 2. WowWee MiP Robot Tire Replacement: adım 5, 3 resimden 3.
    • Separate the rubber tire from the rim.
    • Push the collar out to separate the plastic layers of the wheel.
    • When reassembling, align the groove and the key of the two wheels' halves together.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Moira Keahon
257 İtibar
3 adet Kılavuz yazıldı
Ekip
University of Maine, Team 1-50, Diaz Fall 2014 University of Maine, Team 1-50, Diaz Fall 2014 üyesi
UMAINE-DIAZ-F14S1G50
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
my MiP has plastic over his wheels
Clarrie O'HARE - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 6,765
