Giriş
This guide is designed to help users remove MiP’s wheels. MiP has two wheels that are connected to its body with screws. If the wheels need replacement or cleaning, follow this guide.
Neye ihtiyacın var
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
Separate the rubber tire from the rim.
Push the collar out to separate the plastic layers of the wheel.
5 farklı kişi bu kılavuzu tamamladı.
The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
donna.hester7 - Yanıt
