Giriş
This guide will lead you through the process of opening the battery panel of the WowWee MiPosaur for the purpose of replacing batteries.
Neye ihtiyacın var
Use a Phillips head #1 screwdriver to remove 3 2mm screws from MiPosaur's underside panel.
Bir Yorum
Moving the MiPosaur along the ground will give it a burst of power, and so can create an electrical hazard when touching internal parts. If you keep moving it, the low battery sequence will commence and it will power off, even if the power switch is set to off. If you want to do this, drive it in fast circles.
