Ana içeriğe geç
Wyze Cam V2 Motherboard Replacement
Neye ihtiyacın var
  1. Wyze Cam V2 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Motherboard Replacement: adım 3, 2 resimden 1. Wyze Cam V2 Motherboard Replacement: adım 3, 2 resimden 2.
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Motherboard Replacement: adım 4, 2 resimden 1. Wyze Cam V2 Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    $3.99
  5. Wyze Cam V2 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Motherboard Replacement: adım 7, 1 resimden 1.
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
Sonuç
Oluajo
243 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 402
